Since this is a home theater forum asking about car mobile applications is difficult to answer.
A small sealed box with high enough power to overcome the really low sensitivity will produce okay bass above 35 Hz (fs=37.68) , having a Qts at 0.486 is pretty low control on the motor thus driving toward small sealed box to provide enough dampening.
They are good for getting loud at an inexpensive price and their customer service is pretty top notch. I wouldn't be afraid to try them.
Has anyone used Sound Qubed s-woofers before?
Just currious was think about trying one for mobile use but have not heard of them before.
http://www.soundqubed.com/HDS310_p_225.html
Just put in two 8's ...sound q is very good for the price but the 8's dont play super loud obviously . so if your limited on space I do recommend them... do you have a space / budget in mind ???
