1 - 20 of 123 Posts
Re: SonoSplinter RL-P15 build
My plans are changing all the time:mooooh:, triple bottom and top, and yes i`ve decide to brace the port. The encloseres you see on the left is my diy satelites.
Get your largest roundover bit..... That's your size... :)
Seriously, I have 6" ports and a 1/2" roundover, and no chuffing.
My largest routercutter is 30mm, but then the donut is going to be 60mm diameter, and thats large.
Have also a 15 mm cutter and if you dont have any chuffing thats the size i`m going to use.
You'll love them!
Beware though. Mine are jumping a bit on the floor at insane levels. I've been told it's because I have no baseplate. Maybe you should consider that in your design.
that looks awesome. more pictures! hehe.
1 - 20 of 123 Posts
