1 - 7 of 7 Posts
I was wondering if anybody has any suggestions for rather small/minimalist seating for my media room (I searched for a similar topic and didn't find one). We have just movied into a new place and the only room I can set up for my theater is rather small (approximately 12' x 12'). Ideas I've had include a smaller thinly-cushioned/backed couch (don't know what else to call it, not big and plush), futons (if I can find comfortable ones), and maybe the convertible ottomans that I've seen suggested for overflow seating. Also, some of those oversized foam/bean bags might be a possibility.
It's our first home, so I'm not looking for a professional theater feel or anything. Just trying to do the best I can with what I have to work with. As long as I can have somewhere for a few (maybe 6?) people to sit comfortably during a 2 hour movie, that's fine with me. So if anybody has had a small room like this before, feel free to share your solution.
Thank you for your help!
larrivee7,
You can check the Berkline 12006 and 13175 narrow profile Home Theater recliners. They are available in bonded leather/vinyl combo and leather/vinyl combo. They are quite comfortable and relatively not very expensive.
12006: http://www.rtheaters.com/specials/Berkline12006.html
13175: http://www.rtheaters.com/specials/Berkline13175.html
The major difference between these two groups is in the height of the back. The 12006s have a lower back (38'5") and wil be a good fit for folks who are up to 5'8". The 13175s will have higher back (42.5") and work better for the guys who are between 5'10" and 6'2".
12" width should be good enough for most couches on the market. I think standard size would be 7 to 8 ft wide. A narrower couch or a wider loveseat might do the trick if you want to be able to walk around the whole seat and only 1 or 2 people will be watching movies. You could always have a standard loveseat and use some occasional chairs for when you have friends over.
You'd really have to go out and shop around to find something you like style wise. Bring a tape measure and a sketch pad with your rough room drawn out and plot away in the show room. A good furniture store will have staff that can assist.
If budget is a real big concern you could visit your local second hand store and then get a slip cover if you don't like the upholstery. Try www.kijiji.com too and your local paper. Sometimes people practically give away their old furniture.
Lots of people here will advise against a 12x12 room as it plays havoc with acoustics. They will also recommend against putting seating up against a wall. You have what you have though and making it comfortable might be the #1 priority in your wife's eyes. IMO a HT, regardless of design, is better than no HT.
Ive also seen people use beanbag chairs in there theater room and dont take up alot of space.
1 - 7 of 7 Posts
