My last thread turned out to be a feeler and was instrumental in getting me back into the "know". But I've got some actual specs now and need to narrow down my driver choice.
My previous thread:
http://www.hometheatershack.com/forums/diy-subwoofers/15810-10-small-enclosure-hmmm.html
My project almost exactly mimics this on a smaller scale:
http://www.hometheatershack.com/for...3-diy-subwoofer-would-like-some-feedback.html
So, check out the rough drawing I made. The top will be 22"x16"x16" to keep the math simple. It'll be 20" high and top-firing with whatever port recommendation y'all think is best. The numbers put it at about 1cuft all said and done calculating for the volume of the materials and ports. WinISD calls for a 3"x14" to get me 30hz for most of the 8" subs. The pic below shows 2x2" ports, but I'm thinking a single 3" wins.
So, back to driver and amp selection.
It'd be easy to go with the Dayton RefHF 8" and the 240watt plate amp and call it a day. At under $250 shipped for the amp/driver/terminals... it's a frontrunner. For an extra $100, Soundsplinter sells an 8" driver, but not sure it's $100 better. Any other 8" drivers I should consider in the $100 pricerange that might be a better deal than the Dayton?
Thanks for the help!
Pics are of initial design, space behind TV, front of TV.
My previous thread:
