1 - 5 of 5 Posts
I am using a UMIK-1 mic in conjunction with REW. Is there a way to connect 4 umik-1 mics via a cost effective multiplexor for real time spacial averaging ? Most multiplexors are XLR based and have a rotary switch that allows individual or all mics selection.
If you’re talking about the ability to use all mics simultaneously, I doubt such a USB device exists.
Thanks Wayne, it would far too time consuming to use 1 mic in 4 positions and average the readings. XLR based multiplexors do exist but they're like $1,500 and are designed to work with XLR mics.
If you can connect 4 UMIKs to your computer and REW can see them, maybe you could write few lines of script to automate UMIK selection with Autoit or similar software.
1 - 5 of 5 Posts
