1 - 5 of 5 Posts
Plain ole user
Be careful with tape with a strong adhesive. You don't want to do damage. I have used freezer tape or painters tape because they come off clean, but sometimes you need a little more stick, depending on the material and depth of the dimple.
Agree with Icaillo, use a painters tape - the blue one or Frog tape. It works well but won't fix the 'creases' if there are any.
1 - 5 of 5 Posts
