Hello, I have a quick question. I just set up my home theater which I have had put in storage for a while. I could not find my 10 gauge wire's for my mains and center so I used 16 gauge instead. I can't believe that my speakers sound so much better using 16g instead of 10g. It has me baffled. The difference is like night and day. I have read many time that using lower gauge wire is better and produces a better sound but not in this case. The receiver is rated a 75w per channel. So i am thinking that since it a low wattage per channel that not enough power was sent to the mains and center because of the bigger gauge wire. Is their truth to this. I need clarification on this issue. Thanks! Here is a list of my equipment
Yamaha RX-v630
Boston acoustic CR series fronts, center, and surrounds
SVS PB-12/2 Subwoofer
All speaker settings on small on the receiver
Yamaha RX-v630
