1 - 9 of 9 Posts
I am little bit confused where to start the room acoustic analysis for Home theatre setup. First priority is for low end and the second priority is for mid and high end analysis. My question is Whether to choose SPL meter with line out like galaxy audio cm 140 or linear condenser mic like Behringer ECM 8000 . And also which affordable speaker is best for room analysis purpose.
my room is a untreated room.
i am going to use it for 5.1 home theatre setup.
i would like to treat room with acoustic panels, bass trap based on the room analysis.
for that i am not sure what are the things to consider.(acoustic or frequency analysis) ?
Discussion Starter #7
thanks for ur reply.
so what first purchase i have to make?
galaxy cm 140 spl meter or (behringer ecm 8000 / presonus prm1)
Super Moderator
Like I noted before, the cheapest thing you can find will work. If your computer has a line-level input, the Galaxy meter will work. If not, you’ll need the ECM/Presonus setup, or something similar. The mic will require an audio interface.
But if you go to that much expense, it makes more sense to get a calibrated Dayton EMM6 from Cross Spectrum Labs. The calibration will make it more accurate than the Presonus mic, for the same price.
Discussion Starter #9
Thanks for reply.
I have narrowed my purchase to spl meter with line out.
Again I need ur help.
Can we do low end acoustic measurement using spl meter?
In my country extech 407730 is lesser than the galaxy cm 140 ?
Can I buy extech 407730 ?
1 - 9 of 9 Posts
