1 - 4 of 4 Posts
Gday i am in urgent need of the SRC 3000 remote codes to suit a Thomson RP 46 rear projection television. The main function I am after is the menu key to enable me to get into the on screen test patterns to hopefully resolve a convergence issue.
Any help gratefully appreciated.
Plain ole user
Who makes the SRC3000? What model Thomson set do you have?
Gday the Universal remote I have is the sunwave src3000 with the blue lcd touch screen, and just to add to the confusion the television is badged as a general Electric whilst the model number and research i have done says it is in fact a Thomson. any suggestions? I have been to the Sunwave website and tried about 50 different codes, none of which work.
Have you tried the learning feature with your TVs remote? The SRC-3000 manual says that it can learn:
from page 11 of the manual
Learning Function
You can use this function to learn the IR codes
directly from another remote control. This function is
perfect for newer or less common devices. You can
also use the function if a certain key does not perform
the desired function after using the CODE function.
However, if you have the problem that the SRC-3000b
cannot learn your device codes, please refer to
“Troubleshooting” on page 36 or contact SUNWAVE.
1 - 4 of 4 Posts
