41 - 47 of 47 Posts
Hmm. It does look like a filter is on. I'm guessing that it is something in the SRM control panel settings. Not sure what as I don't have it to look at right now.
It's still a little bit more rolled off on the low end than the usual, but much better. If you aren't concerned with measuring below 10-15hz anyway who cares.
What was the problem?
It's fine.
To prove it's OK, simple connect a cable from the right channel line-out to line-in (just as you did to make the soundcard cal file), and take a Measure from 0-10000Hz. (be sure to run the Check Levels routine and Calibrate SPL first).
The resulting measurement should return a perfect straight line, if your cal file is correct.
41 - 47 of 47 Posts
