I am trying to optimize the sound in my family room.
With my large subwoofer in the only WAF-friendly location, I found a large cancellation at around 40Hz in my listening position. I was able to compensate for this by integrating a second small sub next to the center channel and applying a little EQ. I now have a much smoother subwoofer response at the primary listening position.
Next up was to do full-range measurement of the response at the listening position. Below is a REW plot of subs plus center channel from 15-20k (black) and subs plus L+R mains (magenta). I also measured L and R separately and they both overlay onto the magenta L+R graph (data not shown).
Yikes!! :yikes:
As you can see, my previously identified mode of 38-40Hz appears to also rear its ugly head at 10 times the frequency. To map the 40Hz mode spatially, I played a test tone and walked around the room with my SPL meter. There is a standing wave across the width of the room, with its null at the listening position, and a peak along each L/R wall. Spatially, it is one giant cosine wave with the left wall representing x=0 degrees and the right wall representing x=360 degrees. It doesn't matter where you stand in the length dimension - you can walk the length of the room in a straight line along the null or one of the peaks and the sound meter doesn't change.
The room is shaped kind of like a barn with the back torn off - in back, there's an 8ft x 10ft opening to the kitchen and beyond to the rest of the house. The ceiling is vaulted, but symmetrical. The right wall has a fireplace and two windows so I can't do much there. The left wall is solid sheetrock - I could put some absorptive devices there but I know that 400Hz is close to the lower limit of what typical absorptive panels (like OC703) can handle.
What about diffusors? Is this hopeless?
Yikes!! :yikes:
