1 - 5 of 5 Posts
Sorry for this repeat post - it is now in the correct place.
Hi- new to the forums:smile:
I have a pair of diy speakers that are 'open air' - i.e not even a baffle.
The two woofers each side have to be carefully equalised so as to not result in too much excursion at higher volumes.
I am using REW to generate different filters for the woofers and the mid/high unit.
Using eight uncompressed audio feeds via hdmi, enables me to allocate different filter corrections to the separate drivers
I need to include a brickwall filter - or something pretty steep - at 40hz, to make sure no lower gets to these woofers.
I would also quite like to make the crossover frequency quite steep as well.
Any idea how I can get more than 12db/octave using REW 'generic' filters?
I am using 'generic' filters because the filter data is exported to Equaliser APO for final output to a multichannel amp.
Any advice would be much appreciated
Don
Each filter in REW is a single biquad, so 2nd order, 12 dB/octave. You would have to use multiple filters to get faster rolloff.
Hi John, thanks for the reply.
So am I right in saying ( having searched this, as it is not my subject ), for a single 2 pole filter, a Q of .7071 is optimal?
If I cascade two ( i.e a 4 pole filter ) , then from what i read two different q values are needed? - that is .541 and 1.30?
Also will two cascading filters give 24db/octave, and so on?
Thanks
Keith
Yes, that's pretty much it. Higher order filters can be decomposed into a series of biquads. If a set of LPQ filters with the same cutoff frequency and 0.7071 Q are cascaded then the attenuation at the cutoff frequency increases by 3 dB for each extra filter and the rolloff increases by 12 dB/octave. The different Q values compensate for the attenuation at the cutoff by adding some peaking to pull the response back up to -3 dB. You can see the effect in REW's EQ Window if you turn on the option to show individual filter responses.
1 - 5 of 5 Posts
