1 - 3 of 3 Posts
Searched the forum multiple ways and couldn't turn up mention of it. Price seems about the same as the UR22, biggest difference I can see from the Steinberg site is the addition of "loopback" functionality.
Has anyone used this device with REW? Is the loopback the same as what is needed for a reference channel? If so I suppose that would save a cable, and the slightly higher SNR doesn't hurt.
Please see my comparison found here: http://www.hometheatershack.com/forums/rew-forum/146858-usb-audio-interface-sound-card-comparison-m-audio-presonus-steinberg.html
Please post any questions in that thread if they pertain to my measurements or the UR22mkII.
I would definitely NOT buy the UR22, but the UR22mkII as several issues appear to be fixed. I really like my UR22mkII, it blew away everything I tested it against as far as freq resp and THD. Also, noise floor for the mic input is below 125dB at mid level.
OK, cool, thanks. Not sure why I couldn't turn up that thread in a search. Some forums are a bit wonky that way I guess.
1 - 3 of 3 Posts
