I think was the best forum to post this question.
I have several question concerning the removal of heat build up within a wooden cabinet that stores my stereo equipment. The cabinet has 3 separate compartments and I do not want to cut vent holes within the internal walls. Therefore, I am looking for an intake/exhaust thermal controlled fax system for each (3) compartment.
Looking at the AC Infinity fan systems it appears each cabinet fan system will have a 19 DbA sound rating. Am I correct in thinking that if all 3 fan systems are on at one point, I will have a sound rating of 57 Dba (3 x 19)? If all fans are located in the rear of the cabinet, which will be about 4 inches from the room wall, will 57 DbA noise level be audible from 10 ft away from the front of the cabinet.
I found AC Infinity on the internet so I used them as reference. Are there other manufacturers of cooling fan systems on the market are better or more reliable? Any comments, suggestions or recommendations would be appreciated.
thanks
Joe
thanks
Joe
