1 - 12 of 12 Posts
Hi all.
Long time lurker here but need your help, thus the post.
I'm sure the audiophile-stereo thing has been discussed before but I'm not digging up a huge amount of satisfaction from the web. Forgive me if this is in the wrong section or has been discussed before.
The equipment situation summed up:
Denon 2105 Surround receiver running pre-out for main L/R into a NAD 319 powering some tasty floor standing speakers.
The surround sound makes some reasonable quality noise and that's good enough for me (I feel some of you cringe already), but I listen to stereo music through the NAD only.
So, the question? How do I simplify!
I'm sick of maintaining 2 amps; The NAD is beautiful sound but very unreliable and I think the Denon needs some work now as well.
Also, really I don't want to turn on and deal with audio input selection on 2 deveices, along with the manual volume matching of the NAD when I movie-up and use the surround.
Why don't I just hook up the Floorstanding speakers to the Denon 2105 surround amp and use this to play stereo music? Because, in short, it's sounds like garebage - just doesn't compare to powering those babys with the NAD.
So is there a one box (single amp) solution here? Other options?
Any help or thought provoking discussion appreciated.
Cheers,
FM
Hi all.
Cheers,
FM
Sure. What are your budget and specific requirements?
Hey there. Thanks for your reply.
Budget? No budget, it's free scope! Having said that, I don't think I need to invest in the $37,000 Musical Fidelity AMS50 Class A Power Amplifier.
Really, I'm taking a pragmatic view and just getting "decent sound" so I'll just say keep costs low. I can say that safely in this kind of forum since I doubt people here would recommend cheap and nasty stuff.
Specific requirement was the "one amp" solution, although I don't know of there is a Surround sound amp that will supply quality stereo sound given shared power source and quality deteriorating digital sound processing. I thought I'd get ideas here for another solution.
Really, it's all about installing a sonos system in the house... and for the loungeroom I just want to be able to turn 1 amp on, and select sonos as an input and walk away.
Currently I'd have to switch on 1 or 2 amps , potentially flick 2 speaker switches and adjust volumes - along with reversing all that to sit down and watch some TV.
Cheers,
FM
Hello,
The Arcam AVR600 might be just up your alley. While certainly not cheap, it is decidedly cheaper than $37,000. Many believe the Arcam offers the best 2 Channel performance of any AVR out there.
Truth be told, Onkyo's upper tier AVR's also offer a very solid amplifier stage. The TX-NR3010 and 5010 both are THX Ultra2 Plus Certified and weigh around 60 lbs which is close to triple what your Denon weighs.
Cheers,
JJ
Arcam AVR600. Definitely a serious beast.
Ok, yes, I should have specified a budget. If I can spend $1K to $1.5K on top of quitting the 2 old boxes then that could be a one box solution - if they make good stereo performance for cheaper amps. Looking atthe price of the QArcam mentioned above, I don't hold a lot of hope here.
Good thinking and suggestion thank you, but out of my budget.
Cheers.
FM
Hello,
Cheers,
JJ
:T:T
I'd consider Emotiva with maybe a Nad Preamp or even Marantz AVR.
:T:T
Hello,
That sounds like an excellent plan of action.
All the best,
J
If the Denon AVR-2105 sounded like you-know-what in stereo, then you probably won't be happy with ANY modern receiver offerings in the $1000 to $1500 price range. They are really skimping on the audio portion in AVRs to provide more convenience features and digital connections. Only the top two Denon units even have pre-outs these days. Onkyo does a little better and provides pre-outs on their top 5 receivers stating at their TX-NR7xx and up.
Something your old Denon doesn't have is room correction. Both Onkyo and Denon use Audyssey, which is pretty-much the standard in automated room correction. That alone could make a difference in your situation. All you have to do with Audyssey is set up the included mic on a tripod, start a measurement, and step out of the room for about 10 minutes per location.
Check Accessories4less or Amazon for the best deal on Onkyo TX-NR709, NR717, NR809, or NR818. These should be $450 to $780 refurbished plus another $70 or so will get you a 5-year extended warranty. I'd only look at the Denon AVR-3312ci/3313ci or 4311ci since only those have pre-out. $670 to $1150. All of these should get you roughly the same power output as your NAD at 8 Ohms
I'd just start with a new receiver first and try that out. You can integrate your NAD with it and probably have better control of it with a new AVR. Not sure if your NAD has a 12v trigger. If you want to try another amplifier, then the Emotiva XPA-200 is proving to be a decent stereo amp at $420. Looks like it does about 125w x 2 with a decent THD.
Marantz does pre-outs on many of its receivers and is well regarded for its musicality.
Marantz is essentially part of Denon and I'm sure they share at least some R&D. They don't have nearly the spread of AVRs as Denon has but they have a lot more pre-pro and amp options. I did notice that Marantz added pre-outs on the SR5007. They weren't on the SR5006. The SR5007 is probably similar to the Denon AVR-2313ci but has preamp outs.
Years ago my Denon AVR came packed with a Marantz remote. LOL
I'm not too surprised. Onkyo and Integra share the same remote, just different silk screening of the logos. Both are about 70-90% interchangeable.
http://www.hometheaterforum.com/t/199026/marantz-vs-denon
1 - 12 of 12 Posts
