I have been studying REW video tutorials and the manual for days. I initially had problems getting things working but have finally made it through these steps:
Calibrated soundcard via feedback loop
Calibrated SPL, balanced mic input to match pink noise
Did the sine sweep to measure the room
Generated EQ correction curves to compensate for my room
But when I click the "Predicted" graph, it looks NOTHING like I would expect (and nothing like the example I saw on Youtube, which made the new curve relatively flat.)
I had a few issues when doing the calibration.
One was that b/c you need to put a mic in front of a speaker, and that mic'd sound goes back into the system and back out the speakers, I was having a problem controlling feedback. I turned my SPL down to the min. recommended amount but I still heard a small feedback resonance (at an exact frequency) sometimes. I did the sine sweep over and over until I thought it recorded no feedback but I can't be sure. Why would REW play the mic'd pink noise back through the speakers instead of just listening and measuring?
The other was that I saw conflicting opinions of how to angle the mic. I have a Behringer ECM8000. I saw opinions that you should 1) Point it up to the ceiling, 2) Point it directly between the speakers, and 3) Point it between the speakers at a 30 degree angle upwards. I chose #3. But wouldn't doing it any other way give a different reading? If so, how would one know which one is correct? It's an omni mic but placing off-axis like that should change the frequency response, shouldn't it?
So keep those two points in mind when you see my graph. Maybe I did something wrong that made this strange predicted frequency fix happen. I've attached both a JPG and the entire data set. The purple is the "Predicted" results.
Thanks for any help offered!
