Hello fellow Shackeroonies,
I've spent two weeks grappling with a Popcorn Hour A-110, and I'm delighted with it. It took a whole lotta fiddling and faffing, but the effort I've made is definitely showing...
... there's only one respect in which playback is less-than-stellar, and that's audio-sync. It's not a very common problem, and I know it's not the A-110's fault. Some of my DVDs date back to 1997/8 when DVD was new, and at that time certain discs were known to have audio-sync problems with certain (usually cheaper) DVD players. Now that I'm ripping these DVDs for playback on the Popcorn Hour, I'm noticing this problem again for the first time in years. And it's terribly annoying!
Normally my remuxer of choice would be tsmuxer, but that only outputs .ts and .m2ts files, and I need to output .vobs because my DVDs are arranged in video_ts format. I was advised on another forum to try avidemux and/or videoredo... and, basically, I've found them to be useless. Yes, they output compatible files, but they insist on compressing them (I absolutely HATE video programs that don't have an easy-access "lossless" option...), and the audio-sync is still bad even though they insist that it's been corrected. Like I said - useless.
Is there any way to pull .vobs out of .ts or .m2ts containers? If there is, I can user tsmuxer (which works excellently).
Thanks a lot, as ever.
DH.
DH.
