1 - 3 of 3 Posts
I have 2 subs that need equalization, large part of which is a high pass filter. I have been searching the forums and googling, and seen a few, not that many really, options. The reckhorn is a fairly common use for the purpose, but not available readily it seems. Anti-mode seems to be popular. The DCX2496 is an alternative for some people, but to be honest, I am not interested in pro audio components. Is the anti-mode worth the extra money? Is the reckhorn easier to find than it seems like? What is the best option to get performance from 2 individual subs if the cost of either option isnt an issue?
Thanks
Brandon
If you have measurement equipment and really want to get the best functionality and bang for your buck, you'd get something like a BFD or minidsp. If you want ease of use, get a antimode. If you want to go cheap, build your own 1st-order passive (extremely simple to make) or 2nd-order (or higher) active high pass filter.
1 - 3 of 3 Posts
