1 - 5 of 5 Posts
Hi all I hope someone can help me and not sure if this is the correct place to ask this question.
But here goes , I have a Jamo sound surround With a powered sub and when we have a power cut and the power comes back on the jamo sub overheats around the connection from the amp I think it is called RCA but if i unplug it and plug it back in it works .
If anyone could help that would be excellent.
Thanks in advance Dell
No but i am sure i can find one surely there should not be any voltage on the earth.
Plain ole user
Be VERY careful. If the connection is get hot there may be current flowing through it. You may ha an open neutral line causing it to return through ground paths. Or leakage current due to a defect or damage.
1 - 5 of 5 Posts
