I have a 12" Audiobahn aw1251t (400w) dual voice coil sub I am looking at using for my home theater setup which will also double as a 'party' system if you want to call it that. The sub is brand new but I know its definitely not quality, it will just have to do though.
I have a 3/4mdf single 12" box left over from my old 330i, and when I moved to my A4 the factory bose was decent enough for me not to want to add anything...so I have that to work with.
The box is fairly big, but the port is about 12x1.5" at the bottom of the box. I think this is definitely too big, what are thoughts on sealing the port up and putting in a smaller tube port? possibly two (one on each side).
I will have to cut a square piece out of the back of the box for the dayton plate amp I'll be buying sometime very soon...so i figured while I was doing that I might as well get whatever else I want to do at the same time.
I will post pictures of the box and sub here fairly soon.
Suggestions/Input would be wonderful.
Thanks ahead of time!
