I added some fiberglass bass traps to my front corners and decided to play with sub locations again. Right now I'm using two mismatched subs - One on each side of the TV cabinet. I disabled the EQ and ran a sweep. Then I moved a sub 1/2 way to the corner took a sweep. Moved it into the corner, another sweep and then repeated the process with the sub on the other side.
The first sweep is dark blue and has the lowest output between 60 and 100hz. This is the placement I have been using because (In normal use) I'm applying EQ cuts to several frequencies from 40hz on up and this location lets me use the least EQ.
Is this line of reasoning logical? Any ideas on why sub placement and 6" thick corner traps have so little effect on the 20 through 50hz range?
