So my friend is a design student and graduating. he has to do a senior studio project and chose some speakers. I am in charge of choosing the sub and giving him the requirements for space and what not to develop around.
His budget per sub is ~$100, he will be getting the Bash 300 watt plate amp. There will be 2 10" subs, one in each tower. Bottom firing with a port firing towards the listener (port optional depending on sub). the enclosure is relatively between 1.2-1.75 cuft in space.
I have been looking for a good driver in that price range and have come up with this:
RE Audio SRX 10
Now i dont expect to have you guys list off a ton of suggestions or anything. just if there is something that looks better spec wise then this guy. These look like a pretty good deal.
10"
Electrical Q Value -Qes: 0.39
Mechanical Q Value -Qms: 5.5
Total Speaker Q Value -Qts: 0.36
Free Air Resonance -Fs: 25.3 Hz
Equivalent Compliance -Vas: 31 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 85.3 dB SPL
Effective Piston Area -Sd: 310 cm^2
DC Resistance -Re: 1.8 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 300 W
Force Factor -Bl: 14.35
http://cgi.ebay.com/PAIR-RE-AUDIO-S...Car_Subwoofers_Enclosures?hash=item45ee4eac2b
RE Audio SRX 10
10"
