1 - 7 of 7 Posts
i have a sub out of a klipsch rt10d subwoofer a friend let me have. the surround came unglued and he replaced his with a new one and gave me this one to repair.
anybody know the specs on this subwoofer? thanks.
Here are the specs:
  • AMPLIFIER POWER: FTC rated power: 700 watts continuous @ <2% THD
    Dynamic power*: 1600 watts
  • BUILT FROM: 2006
  • DEPTH: 18.75" (47.6cm)
  • DRIVE COMPONENTS: Ultra high-excursion 10" (25.4cm) Cerametallic cone, front-firing woofer
    Dual ultra high-excursion 10" (25.4cm) Cerametallic cone, rear-firing passive radiators
  • ENCLOSURE TYPE: Bass-reflex via dual rear-firing passive radiators
  • EXPORT VOLTAGE: 220 VAC 50/60Hz
  • FEATURES: DCS control and feature set w/ 5 system presets and Adaptive Room Correction
  • FINISHES: Cherry or Black Ash wood veneer
  • FREQUENCY RESPONSE: 22-120Hz +/-3dB
  • HEIGHT: 15.8" (40.1cm)
  • INPUTS: L/R line-level RCA jacks, USB 2.0
  • MAXIMUM ACOUSTIC OUTPUT: 119dB @ 30Hz 1/8 space, 1m
  • OUTPUTS: L/R line-level RCA jacks (pass thru)
  • VOLTAGE: 110/120 VAC 60Hz
  • WEIGHT: 58 lbs (26.3kg)
  • WIDTH: 20.5" (52.1cm)
Discussion Starter #4
thanks, i was actually looking for the ts for the woofer only so i can model it. i just have the driver out of the enclosure. i fugured it would make a nice little project speaker, if not i guess i can pick up some pr's off ebay and copy the original design.
Discussion Starter #6
no where that far into it, im just fishing for info now. too many other projects to get done first.
119dB?! Is that even possible for that sub and power?
That's a1/8 space measurement, the sub is in a corner of a room. That provides lots of boundary gain. And of course they never mention the size of the room. The smaller the room the more gain you get.
1 - 7 of 7 Posts
