K
kes7u
·Guest
I am in the process of building my home theater. The theater room is 15 x 20 feet with sloping of the side walls resulting in room height of between 6 and 10 feet.
I want to use 2 subs in the room, placed in the front of the room out of view. (Behind side walls / screen wall) In a room of this width, the research I've done suggests placement of the subs approximately 4 feet from the left and right side walls in order to be in the 'null' area.
My options are as follows. Place the subs as described above. This would limit me to 2 of the sb12-plus subs, as I only have about 14-15 inches behind my screen wall. Alternatively, if I place a sub in each front corner, I could go with a couple of the cylinder subs as there is more room here because the screen wall does not extend that far out.
I plan on using the room for 75 percent movies, 25 percent music.
Help!!
Thanks.
Kevin
Help!!
Thanks.
Kevin
