1 - 20 of 57 Posts
SUBWOOFER ONE TO ONE DESIGN SERVICE
This service will be for ported, sealed and Passive Radiator subs.
Once the optimum box size, port size etc.. has be determined in WinISD I will then create a 3D SketchUp drawing off the model. Once the drawing has been approved by the customer then I will create a cut sheet showing all dimensions and then produce a 2D flat sheet with the pieces on the mdf sheets so you can see how if fits and how many sheets you will need.
We all know that there are big savings to be made from building your own subwoofer in comparison to commercial subs and this is by no means to take anything away from commercial subs as there are some greats out there.
But it gives you great satisfaction knowing you have built your own.
Also included will be a step by step guide on how to build and what piece to glue on what and at what stage so it makes the whole process pain free as it was very scary for me when I build my first sub.
I am available to answer any questions throughout the build stage and have even been known to make phone calls from the UK to the USA too.
The charges for this service are listed below:
Single Sealed subwoofer
Design and cutsheet: $50
Step by step guide: $25
Dual Sealed subwoofer
Design and cutsheet: $75
Single subwoofer with one Passive Radiator subwoofer
Dual subwoofer with two Passive Radiator subwoofer
Design and cutsheet: $150
Single subwoofer with two Passive Radiator subwoofers
Design and cutsheet: $100
Small Single Ported subwoofer (0 cu ft - 5 cu ft)
Medium Single/Dual Ported subwoofer (6 cu ft - 10 cu ft)
Design and cutsheet: $125
Step by step guide: $50
Large Single/Dual Ported subwoofer (11 cu ft +)
Design and cutsheet: $175
Feel free to ask any questions or give me a shout if you are interested.​
I'm really intereted in this service.
Which information do you need to make new design for me?
How can I contact you?
Actually I'm new in here.
Thank you.
Great idea Graham. Don't be surprised if you get very busy...:T
Great :T The next step is to do some studying :reading::reading::newspaper: and become a quarter-wave expert :eek:lddude:and charge triple for that!
I have just had Graham design a enclosure for me, overall the experience was good he changed the design that I had in mind to work out better and making sure it was still what I wanted and provided me with a cutlist with pics of how to set them out on the sheets for the least wasted materials.
Ash
Graham, I don't think I can send you a PM yet because I don't have 5 posts, but I am interested in buying your designs and instructions.
I have *four* 18-inch Mach5 IXLs that have been just sitting around. Do you recommend four different boxes or combining the drivers.
I have plenty of space in my theater room for four very large enclosures. I am, of course, looking for the best performance. Do your instructions include what to do after the boxes are built? This will be my first speaker build of any kind.
I will PM you after I have five posts (this is #1).
Thanks.
I am new to the Home Theater Forum. Graham designed a couple of 6 cubic foot boxes. Could not be happier!!! Great guy to work with and very responsive for being half way around the world.....
I can't wait. Did your instructions only include building the enclosures or do they explain what to do after the enclosures are built?
He included how to build, drivers to use, basically everything. Graham is so easy work with. I last looked at my email inbox and we have had over 100 emails back and forth. He is very willing to help make sure it is right. As I said before, great guy and very knowledgeable. You won't be disappointed!!!
1 - 20 of 57 Posts
