1 - 3 of 3 Posts
Some time ago I built a Aperiodic subwoofer enclosure utilizing a 15 inch DVC Madisound driver (8ohms) and a pretty cheap 70wat plate amplifier.
Up until recently i have been reasonably happy with the result.
However I have since aquired 2 x Marantz MA 700 monoblock amps (200 watts rms into 8 ohlm) and would love to build 2 x 15 inch subs for my H/T.
Australia is a great place to live but trying to find a suitable 15 inch driver at a reasonable price has proved difficult.
I'm now contemplating purchasing a Dayton DVC385-88 15" VC Series Subwoofer from Parts express.The cost is $127.00 US and the freight is $180.00 US.
Having read some of the previous threads, it seems they are a pretty good driver but for $300?
If anyone has a suggestion?
Due to your location it's unfortunate as to the shipping charges you have to pay. Then there's the issues of damage or warranty. If you're forced to pay $300 for a sub then there are a few options in Australia. Depending on what you're willing to go with on sub size and box size, here's a few sites:
http://www.affordabledrivers.com.au/
Mach 5 Audio products that are the best value for the money. You can get a 18 inch for the price of others 12 inch subs.
http://www.essentialaudio.com.au/
Notably the Perrless line of XLS and XXLS subs.
http://www.audiomarketplace.com.au/
Exodus line of subs which are excellent.
Thanks Mike.
Its fantastic that someone on the other side of the planet has information on products in my own backyard.
I have made enquiries with affordable drivers, but i did not know about the other two.
Affordable drivers recommended the IXL 18. Reasonably priced but a low efficiency and not in stock for maybe a couple of months.
Bridging my two monoblock amps would overcome the 87db (apparently a generous figure, actually lower) with 600 watts available, but i'm not sure.
Also having one 360 litre enclosure, rather than 2 smaller enclosures could make more restrictive in terms of placement in the room.
I will take your advice and give the exodus subs a good look, and do some more homework. Its all fun.
Thanks again
Paul
1 - 3 of 3 Posts
