1 - 9 of 9 Posts
Hi , im building my new hometheater on my new house. My space is 15 ft X 21 ft, i was thinking on going with an exodus tempest x . I only have experienced building my front speaker, with came quite well so now im deciding on going for the subwoofer. Any designs or suggestions? help is highly appreciated.
Thanks
Thanks
Your room is similar to mine ( 15 x 21 x 8 ). I am approx. 3/4 through with my first build. I went with the Tempest-X2 and the Dayton 500w amp per Kevin's suggestions. My external box size is 18 x 20 x 52.
It all depends upon your budget, size constraints and what you desire to achieve. The slot ported Tempest is a good value though and I think it would fit most people's needs for a balanced HT/music system with a healthy amount of output.
The Shiva-X2 builds are for those with size constraints and the M-18 & M-21 are for those who want to build an output monster or have the more disposable income.
Kevin Haskins
Exodus Audio
My budget is 700 to 800 dollars, i think a tempest x 2 would be good any build recomendations? im new to subwoofer building
If your not sure which to build, I'd go with the slot ported design, just over 5-cubic feet and the 500W plate amp. That design has good output, is musical and is a good value. You will come in under budget.
An alternate approach, is a Maelstrom-18" in a larger sealed box. Maybe 6-8 cubic feet would be good and use one of the inexpensive EP-2500/EP-4000 amps to drive it. That is closer to your budget threshold but you would have an upgrade path to more output and sealed vs. ported.
Kevin Haskins
Exodus Audio
Always go for the best driver IMO.
I'd build a sealed Maelstrom and pair it with a QSC or Behringer EP2500.
Make sure to pick up the Behringer Feedback Destoyer for an eq.
Subs are much easier than mains IMO. With the exception of cutting the big panels. They require less bracing.
1 - 9 of 9 Posts
