I'm going to build two subs for my HT, my first speaker build (ever). Each will be Dayton 15" Ultimax in 3 cu ft sealed enclosures powered by one EP4000. I'm looking for help with the internal wiring.
I'm planning to use 12 gauge Belden speaker wire (stranded) since I have a 500' spool of it. On the speaker end I'm planning to put the stripped wire ends directly into the spring-loaded connectors. At the connection to the binding posts inside the box, I'm not sure if I should just solder the wire to the tab or if there is a connector that I should use. I'm leaning towards soldering.
Any advice?
sga2
Any advice?
sga2
