1 - 12 of 12 Posts
what can I buy locally to stuff a sub woofer box.... Pillow filling from walmart? Do I need wool? Is this stuff going to catch on fire if the speaker sparks or something? Is that a stupid questions?
Or do I need to buy from parts express? for like 50 bucks? seems over priced for filling...
Afaik it's just polyester fiber, so any poly fiber fill should work just fine, and I've seen plenty of builds that have used polyfilled pillows as stuffing. I bet wool would work to some degree as well, but I'm sure that would be even more expensive. Polyester definitely burns, but so does wood. Glass fiber won't burn, and I think you can use that kind of insulation as well as fill, but it's definitely more messy and irritating to work with.
Radio Shack used to sell speaker enclosure stuffing; not sure if they still do. Some folks use house insulation, but there is a risk of the fibers getting into the speaker basket. I suppose the higher density, the better, since the idea is to absorb the back wave of the speaker so that it "thinks" it is in a larger enclosure. Stuffing it pretty well full will result in about a 25% increase in effective volume, IIRC.
Not enough current to generate enough spark to set anything on fire, even at high volumes. If that was a concern, the paper cone of the speaker would not survive.
HTS Moderator , Reviewer
Thanks.. I just did not want the sub to burn the house down.... haha
You can actually get stuffing labeled "fire resistant", which I would highly recommend. Some amp internals get pretty hot, so it's always a good idea to add the extra protection if you can.
Get some pillow stuffing and you are good to go. I believe rock wool and perhaps the more expensive "speaker" stuffing could be more dense than cheap polyfill, and thus slightly more effective. Worth the huge price difference? I personally don't think so. I've used both and can't tell a difference. There is however, a big audible difference going from no fill to proper fill for both speakers and subs.
What's the best bang for the buck for lining a ported subwoofer? That eggcrate foam at parts-express is about $2.19/sf, or $50 per sub in a LLT. Are we still using fiberglass batts in large ported subs?
Are people using roxul / mineral wool for ported subs too, or just for sealed subs?
I've seen pictures of people doing that, I've also seen people use foam mattress pad.
Sorry to come in like these and i dont know if i am doing these correctly,but for quiet sometime i have been wanting to build Fusseli tower sub,but a few things i needed was distance between floor and ground in my case i need to go for rubber supports since my floor is tile,since having a Tannoy sub which i have never liked the sound,you speak about some modification on the sub what exact are they?when i analyse my system got a strong respond on the 70-100 not a smooth bass its like a Pro bass sound very agressive.
Sorry my English is no longer great.
Best regards
Jose Arraiano
1 - 12 of 12 Posts
