1 - 20 of 26 Posts
Hi guy's, First Merry Christmas and Happy new year. I hope you and yours are well. I finally burned a test cd to test my new diy Shiva and ED subs whisch are located mid wall left of the viewing area and stacked.They are powered by the EP-2500 and taken at the listening position. I ran tones from 20 to 80hz at 5hz intervals and this is with an eq'ed room response as flat as I could get it. Here are the results.............
20hz-102db
25hz-101db
30hz-101db
35hz-101db
40hz-97db
45hz-102db
50hz-101db
55hz-95db
60hz-94db
65hz-101db
70hz-103db
75hz-106db
80hz-104db
Ok, this was with the system calibrated to 75db levels both mains and sub. What good or bad does thIs test show me. Should I go into the sms1 and bump those lower readings up to be more equal or is this something I should be happy with. Any advice you guy's have would be super. THANKS...:T
Hi TC, The results look good. You're within +-3 db almost everywhere (I'm assuming you have measured properly.
My opinion is leave it that way if it sounds good. You're curve should be pretty flat :T
Don't do these tests to check the max output of your sub using sin waves.... You might damage it.
Thanks, I thought sinwaves was the way to do it. What should I have used. Also I used the Rad shack spl meter for everything taking into account the correction for that meter.
Well, with sin waves and enough power it is quite easy to reach over excursion. When I need to know how loud my system plays, I use a loud bass scene from a movie (like WOTW for ex.).
Well that way it is harder to see what is happening at exact freq's. It didn't seem to bother the subs at all. I got clean bass at each step with no funny sounds or mechanical sounds of any kind.
I am talking about Max SPL. Sin waves are OK for FR (moderate SPL and that's the most important. Max SPL might have a different behavior from FR (specially when equalizing)....
DO NOT USE A SIN WAVE AT SINGLE FREQ. TO CHECK HOW MUCH YOUR SUB HITS AT THAT FREQ. PROCEED AT YOUR OWN RISK.
Got Ya........I will be carefull and will test on a movie like you mentioned. Wotw or U-571 should do it, Thanks.
Now you're telling me this :paddle:.
I did that mistake before (I was measuring TSS750 and Velo VRP1000); after a couple of minutes I smelled like something was burning and my AVR was hot ...after those test when watching movies with a lot of bass, I can smell something coming from TSS :whistling:
(To test the subs, I used my reference level and played sinewaves from 10Hz to 200Hz :hide:)
Hey David,
Sorry, I never knew you did tests that way...:no:
Do not worry about smelling things. As far as everything's working OK, you didn't burn anything :T. I don't know your AVR but most of them normally have protections.
Well well well, a short circuit in the speakers wiring cables burnt 3 transistors and few resistances in my Yammie RX-V2500 2 years back. But I was watching a concert at insane an level when that happenned. My guess is protection didn't trigger soon enough, but normally it shouldn't have happened, so do not worry :).
Just use normal material with your SPL meter at LP and measure as you wish.
I use sine sweeps and single frequency tones for my tests (FR, power compression,THD, etc.), but I don't recommend it to anybody. It would not be hard to melt a coil, fry an amp , or hard bottom a driver if you mess up or don't know what you are doing.
That is how I did it. I guess I did it right because I had no problems.
Not having a problem doesn't necessarily mean you didn't stress the driver!
I used to do it also with my old 12" sub (never had a problem, but I knew it was wrong and I didn't care). But I dare not do it with my LLTs for obvious reasons :yikes: :R.... Anyway I believe this kind of test is meaningless.
I agree so I won't be doing it that way again. I will just use a movie or music if I need to.
Me too ... I learned my lesson :sad:
I think a good clip to measure the SPL is the DVE intro ...I think is a plane flying over :scratchhead:
Try WOTW or C&C if you really wanna test the sub :)
What is C&C??? ...Do you mean Master and Commander??? (I watched last thursday :whistling:) ...I have a lot of movies with bass (I need to re-watch Transformers, U571, StarWars, etc. with my new sub :yes:); I was thinking the DVE clip because is easy to find :hide:
Discussion Starter · #17 ·
OK, So my question is do I play the movie at 0 master level because that is where my ref level was set at?
I think you can, but I don't know if will be a good idea, just be prepared...:yes:
Last night I measured at the listening position, I played two clips: Finding Nemo, when the girl tap the fish tank ...the SPL read 110db; then U-571, deep charge ...here I got 100db-106db :yay:
My reference volume is set @ -5.0db not 0.0db (I'm also using a separate amp for the fronts, so I can't use 0.0db as reference); the master volume was set @ -20.0db (so, -15.0db below reference) and it was LOUD!!!! ...I'll be afraid to take a measurement of the same clips at reference levels :scared: . :hide: (but I'm sure I'll get reading above 115db).
Discussion Starter · #19 ·
I use all seperate amps too and it gets scary loud. I never listen that loud but it is nice to have all that headroom.....:yes:
What makes you think you can't use 0.0dB as a reference because you're using separate front amplifiers? Calibration, whether done automatically or manually, will take into account the different gain of a separate amplifier compared to a receiver's built-in amplifiers.
Totally agree though, reference level is LOUD! :hsd: :hush: We did watch Master and Commander at -5dB from reference a few weeks ago though, and subwoofer was actually set 5dB hot, so it was technically at reference level. It sounded quite good, I must say. The canons definitely packed a bit more punch than with my old dynamically limited woofer!
1 - 20 of 26 Posts
