1 - 2 of 2 Posts
I have read differing information on this topic but wanted to get some info from you guys on which is better to use for home theater.
Series vs. Parallel wiring for some subs i'm looking into? I wanted to know what, if any, differences in performance either method would yield.
Thanks
Most importantly, you need to match the nominal rating of your amplifier to the impedance of your subwoofer's corresponding wiring configuration.
Series, parallel, or running a single coil on a DVC sub will all effect the T/S parameters. Although I would expect the difference to be somewhat minor...
1 - 2 of 2 Posts
