1 - 1 of 1 Posts
Martin Logan Dynamo 1500X
Manufacturer Specs
Specifications
MSRP (US) $1,595
Frequency Response 20–200 Hz ±3dB; Anechoic through LFE effects input
Low Pass Filter Frequency 40–150 Hz
Low Frequency Transducer 15" (38.1cm) high-excursion, polypropylene cone in acast aluminum basket with extended throw driver assembly;sealed non-resonant cabinet design. Thermal sensorprotection.
Amplifier 650 watts (1300 watts peak)
Impedance Left & Right/LFE RCA: 20,000 Ohms
Audio Controls Low Pass Filter Switch: Bypass (LFE In), Variable (Left and Right In)
Phase Controls 0°, 90°, 180°
Inputs Left & Right/LFE RCA Line Level, LFE XLR, 12V Trigger
Power Draw Standby: 10W
Idle: 15W
Max: 600W
Room Correction Capability Perfect Bass Kit (PBK) Ready (Sold Separately)
Wireless Capability —
» Resolution —
» Sampling Rate —
» Wireless Band —
» Error Checking —
» Antenna —
» Subs Per Transmitter —
» Maximum Wireless Range —
Weight 52lbs. (23.6kg) each
Dimensions Down-Firing Orientation
(HxWxD) 18.3 x 16.75 x 17.6 (46.6cm x 42.5cm x 44.7cm)
Front-Firing Orientation
19.3 x 16.75 x 18 (49.1cm x 42.5cm x 45.9cm)
Manufacturer Published Measurements
N/A
Frequency Response
Max Output Before Compression
Spectral Decay
Group Delay
Waterfall
Spectrogram
Harmonic Distortion
16 Hz
20 Hz
25 Hz
32 Hz
40 Hz
50 Hz
63 Hz
80 Hz
1 - 1 of 1 Posts
