1 - 1 of 1 Posts
SVS SB1000
Manufacturer Specs
Specifications
**Frequency response graph does not denote maximum output capability.
•2-meter ground plane away from reflective structures (quasi-anechoic)
•24-260 Hz +/- 3 dB
Subwoofer Specs: •Cabinet Dimensions: 13" (H) x 13" (W) x 13"(D).
•Overall Dimensions: 13.6" (H) x 13" (W) x 14"(D) (includes feet, grille, amplifier).
•Weight (unboxed): 27 pounds.
•Shipped Dimensions: 19" (H) x 18" (W) x 18"(D).
•Shipped Weight: 34 pounds.
•Rigid and strong cabinet construction.
•Premium black ash and piano white finish options.
•Front-firing 12" driver.
•Power cord length: 8 feet.
Driver Specs: •SVS 12” high-performance driver.
•FEA-optimized motor technology for low distortion.
•High-power voice coil for excellent thermal management.
•Long-throw suspension for high output at deep frequencies.
•Lightweight cone for enhanced sensitivity and transient response.
•Rubber surround for durability and long-life.
•Dual high-grade ferrite magnets.
•Vented pole piece for greater cooling and low noise.
Amp Specs: •Sledge STA-300D with 300 watts RMS continuous power (720 watts peak dynamic power).
•Efficient and cool-running Class D topology.
•300 watts (720 watts peak dynamic).
•Green standby mode with less than 0.5 watts consumption.
•Detachable power cord with main power switch.
•RoHS compliant, lead-free construction and world-wide safety certifications.
•Auto-On / On switch.
•DSP control for accurate response and refined behavior under all operating conditions.
•Stereo line-level RCA Input & 80Hz High Pass Filtered Output connections.
•Stereo speaker level 5-way binding post input connections.
•Continuously variable low pass filter frequency with disable/LFE setting.
•Continuously variable volume and phase controls.
•Input impedance - 47 kΩ (unbalanced RCA) / 2 kΩ (speaker level)
Manufacturer Published Measurements
Frequency Response
Max Output Before Compression
Spectral Decay
Group Delay
Waterfall
Spectrogram
Harmonic Distortion
16 Hz
20 Hz
25 Hz
32 Hz
40 Hz
50 Hz
63 Hz
80 Hz
1 - 1 of 1 Posts
