Have you used the RTA in REW?
Yes I'm using the REW RTA and EQ functions.Have you used the RTA in REW?
There is no problem with having overlapping filters.As an example, EQ'ing a single driver might require a 4 dB boost at 2125 Hz with a Q of 3.89 (as predicted by REW). Once combined with the opposite driver (summing/cancellation), I might need to do a 2 dB cut at 1895 with a Q of 2.1. Since it's too hard to adjust the first filter accurately, I just create a new filter that overlaps (and works opposite to) the first.
Thoughts on whether this is an issue?
Afraid not, one of the many things on the to do list, but you could use the DCX2496 equaliser setting which has an upper limit of 10, a bit closer at least.Also, is there any way to limit the Q in the "generic" REW equalizer?
