Status
Not open for further replies.
1 - 4 of 4 Posts
This is one of the finest sounding multi channel amps you can buy it has voltage and current taps to simulate the "tube" sound on the two front channels if you like.
It is extremly powerful and will not run out of steam at listening levels that will make you go deaf.
Specifications:power Output:200 watts continuous, per channel, all five channels driven into eight ohms from 20Hz to 20kHz, with no more than 0.5% T.H.D.Power at clipping.
400 watts per channel into four ohms
Dimensions:19 inches wide6.5 inches high15.75 inches deep (including connections)
Weight:45 pounds
Finish:Brushed aluminum and black anodize
I have had this amp since new and it is excellent shape with a minor scratch on the side nothing major and no scratches on the face.
I do not have the original box but will pack it very well for shipping it works perfectly with no issues. original owners manual is included.
I used this mainly for 2 channel listening not for home theater.
Thanks for looking
asking $850.00
1 - 4 of 4 Posts
Status
