Howdy fellas,
Got a Sunfire True EQ (TS-EQ10) on it's way to me, pretty excited. I have a few issues/questions, thought you guys might be able to help.
1. The sub is missing it's microphone, used to plug into the sub and perform it's auto EQ. The sub seems to take a normal 3.5mm jack input, though. It says in the manual to only use Sunfire's mic, but couldn't I just plug in another one and use that? I'm guessing it'd have to be a good mic though, not many cheap microphones pick up on bass very well (That's what it's gotta pick up to adjust the sound/EQ). Thoughts?
2. It's a 120v US sub and I'm in the UK, so 230V outlets. I've heard that many people use subs with a step down transformer without any issues at all, so that seems good. My question is which one to get though? In the manual, it states 600W "typical" usage, 2700W peak. What sort of wattage transformers should I be looking at? I'm guessing something around the 3000w mark, if it peaks at 2700w I want to be able to get that power out of it.
Any help is much appreciated! :T
