True but unfortunately that's only part of the controls.
Per the "Setting up the SB Live!" sound card instructions, the mute/enable fuctions (rec. level, wave, etc,) are containted, or shown, within the Surround Mixer application (per the screen-shots in the instructions). If that applicaiton isn't present, then one of two things is happening. 1) That function is disabled, or 2) An internal default setting is applied behind the system window. If the former is true, then there shouldn't be an issue, if the later is true, then I must have the application to use the SB Live! SC with REW.
I messed around with the SC and REW yesterday and I did get what looked like a reasonable plot. However I was rushed and didn't calibrate the SC...When I do, I'm sure the lack of the Surround Mixer application will prove to be necessary...Or not.
Thanks for the reply, and if anyone can shoot an ISO of the SBLive! installation CD, I'll buy as many beers as required!:yes:
