1 - 9 of 9 Posts
Ok guys, I've been looking for quite some time now for rear/surround speakers. I just upgraded to a Onkyo TX-SR608 7.1. My options are narrowed down to Polk RM7's or RM8's. If I go with the 7's I'll be in 5.1 and point the speakers at the seating area; pretty simple and straight forward and economical. Option B is get the RM8's with are spaced 45* apart. So my question is 1- can I run two channels (7.1) to the RM8 and 2- how do I correctly position it to the seating area??? Am I correct to say the RM8's are Bipole/Dipole speakers?
The RM8 is center channel speaker, and just because it has 2 low frequency drivers, that doesn't mean you can run two signals to it and use it as two separate speakers.
Am I misunderstanding you?
Ah. So the RM8 is not a surround spkr. Ok. I don't know if I should be going with regular speakers and run it in 5.1 or go with some kind of bipole two channel and run 7.1. Could swear I read u can do that somewhere.
Posted via Mobile Device
Saw your other post about saying I should just do a monopole speaker of the correct size.... That keeps things simple to be honest. So the RM7's. Are they decent for surround? Obvoiusly I'll be running 5.1. I like how they mount versatiley. I can mount them on stands, on the wall with their swivel bracket or in the ceiling/wall corner and aim them down. I really don't want to spend more than approx $150/set for my surrounds.
For surrounds, I try to match at least the brand, if not series with the fronts, but it's not critical. The surrounds are not a critical speaker, and at the risk of gross generalization, unless you're listening to 5/7 channel music, any speaker will do. So, the RM7 will be fine, go with what works for you budget and size constraints.
could not find any Betas. Gave up and got a set of Infinity Primus P152's. New. from crutchfield for a decent price, and they threw them in with my Onkyo order for free shipping. Couldn't beat it. Now I just need the Infinity PS212 sub:)
I'd look at other sub options. I love my JBLs, but the HK subs have traditionally been subpar compared to ID brands. Really, that goes for most large speaker manufacturers: they just can't hold the value offered by Elemental Designs, SVS, and others.
10-4. I guess you're right. a Subwoofer is a lot more simpler compare to towers.
1 - 9 of 9 Posts
