Status
Not open for further replies.
21 - 32 of 32 Posts
S
Guest
Re: SVS PB12-NSD *new*
Ilkka,
What is your opinion of the PB12-NSD (new version) vs the HSU VTF-3.3.
Thanks.
Discussion Starter #22
Ilkka,
Thanks.
Sam,
Having measured both of them outdoors and also heard both in my own room, I'd say they are really close when it comes to pure performance or sound quality. Since the size and finish are pretty much identical, I'd get the one that I can get for less $.
S
Guest
Thanks Ilkka. I actually went with the PB12-NSD a couple of months back and I have been very happy with it. I paired it up with speakers from Ascend Acoustics and the two (SVS and Ascend) mesh great with each other.
Discussion Starter #24
Aah, sorry about the late reply, but I think you made a very good choice. :T
S
Guest
Better late than never! You test measurements were actually what pushed me over the edge towards SVS, so thanks for your hard work.
P
Guest
¿What subwoofer is better, this or bk xls300?
I doubt is that between these 2
Better change the question: Which of them has stuck best in cinema for a 30m2 room?
Thanks!!
now i'm torn......i was set on the 20-39 pc-plus....but this thing goes loooow.
any suggestions Ikka?
matt
will be paired with SCS (LRC) and SBS (surr.)
matt
matt
matt
PB12NSD vs. PC 20-39 Plus?
I'd go for the Plus, first of all, you can tune the Plus lower.
I think the better driver on the Plus would give you more output.
If I'm not mistaken two 3" ports of the one port plugged 20-39 should be more than or equal the single 4" port of the PB12NSD
will the plus dwarf my scs front setup?
how would you tune the plus to match with that particular speaker setup?
matt
Congratulations! I believe you'll be very happy :)
21 - 32 of 32 Posts
Status
