1 - 7 of 7 Posts
Hello.
I'm looking my first subwoofer(s) for my home theater and i have some difficulties to decide the best solution.
Basically what i have is very small bedroom 3,60m x 3m x 2,40m (W 11,8ft x D 9,84ft x H 7,9ft) where i currently have tv, blu-ray player, receiver and pair of Monitor Audio rx2 for main speakers.
I will be using my home theater 60% for movies and 40% for music.
My next purchase would be subwoofer and svs website recommends 3 subs with MA rx2 and those are PB12-PLUS, SB13-PLUS, PC12-PLUS.
Prices for those subs in Finland where i live are:
PB12-PLUS: 1600€
SB13-PLUS: 1500€
PC12-PLUS: 1400€
And my budget would be around 1300€
If i stretch my budget i could buy PC12-PLUS but with 1300€ you could get two SB12-NSD.
SB13-PLUS would be great for my use but the price is bit to high.
I looked some opinions about 1 big vs. 2 small subs and it seems that 1 big sub would be the way to go especially when i have only 3 seats in my small room.
I would really appreciate some of your opinions about this.
2x SB12NSD can't match for example a PB12NSD. This is a GREAT subwoofer for the money. It will save you alot of money. I have had these SB12 NSD myself (2) and I promisse you 100 % that 1 PB12NSD will outplay them.
The SB13Plus has been stopped for further production and costs the same as 2xSB12NSD in Norway. I can give you the adress, so you can ask for discount in Finland. The proof is here and I hope they will match the price for you. Lsound.no
So PB12NSD or PC12NSD would be a good purchase since PC12 should have very similar performance than PB12? And price is same for both models. PC12NSD would be a superior for me because it can be fitted in smaller space.
Is the PC12-PLUS worth the extra money compared to PB12NSD or PC12NSD?
Whether or not dual SB12-NSD can outgun a single PB12-NSD or PC12-NSD is really frequency dependent. Dual SB12-NSD will easily outgun a single vented NSD from 40-80 Hz, and match or slightly exceed at 32 Hz. From 20-25 Hz, a single vented NSD will still outgun dual SB12-NSD.
Where did you get the info that the SB13+ is being discontinued?
I see it for sale on their site right now.
1 - 7 of 7 Posts
