1 - 4 of 4 Posts
Here is my Freq Response. I finally got REW up and running. I still have a few questions I will post later.
Below are the FR for before EQing with BFD and then after EQing. I think it looks pretty decent. I thought I would be able to get it a little flatter down low. It seems as though down low looks a little hot. I have the sub running +1 db hot over the mains. This is the measurment of the sub only.
The first graph is without the BFD and the second is with the BFD.
I had REW assign the filters. It gave me 10 cuts to filter. I then added in 2 additional filters which I boosted with 5dbs around 59hz and 68hz.
Discussion Starter · #2 · (Edited)
I thought that it was very interesting that they assigned 10 to 15 db cuts between 25 to about 36 Hz. because when I measured the fr after putting in these filters it didn't come down that much.
New Measurements
I checked the levels again after some advice on here and set the Wave out to 1.0 and the Vol out to .5 then retook measurements. Looks much better.
First is no BFD, Second is with BFD.
Would love to learn how to post both of these on the same graph?
1 - 4 of 4 Posts
