So, how do you tell what the impedance of a speaker is? On most cabinets, it should be printed on a label next to the jack. If the speaker is visible, it may be printed on the speaker label or stamped on the frame or magnet. To measure the true impedance of a speaker or cabinet requires a rather complex procedure involving signal generators, power amplifiers and high frequency AC voltmeters. However, with raw speakers and many cabinets, the ohmmeter function of a digital multimeter can help you identify what the impedance of the speaker should be. Generally, the reading given by an ohmmeter will be about 2/3 to 3/4 of the impedance of the speaker. So, a 4 ohm speaker will typically measure about 2.5 - 3 ohms, and an 8 ohm speaker will typically read about 5-6 ohms, while a 16 ohm speaker will measure around 12 ohms.
