1 - 3 of 3 Posts
I am looking to build a small sealed sub using a TC Epic 12. I have an EP2500 from a previous build. Will the EP2500 be way too much for the sub using just one channel? I plan to build a second sub in a few more months and would use the second channel on the EP 2500.
Thanks in advance for the input!
Super Moderator
What size of box? Smaller boxes will allow better power handling, but for a powerfull sub it's going to need to be a pretty stout box. In 1.5cuft for Qtc .7 it looks like a single channel of the EP2500 @ 4 ohms would be about perfect.
Better just make two then :bigsmile:
edit- moved this to the sealed subwoofer build section
Also considering using the ssd12, it's only $10 more, and is rated for a higher power handling. Looking at a 1.6ish cuft box for a Q of .7
1 - 3 of 3 Posts
