1 - 4 of 4 Posts
Guys,
Sorry for the urgent question, but I'm getting construction underway tomorrow on my kickers and riser.
I have an oddball situation, and need guidance.
I have a BKA-1000W amp.
1 Buttkicker Advance
3 Aura Pro shakers
Two rows. 4 chairs up front. 3 in the back.
What are your reccomendations on making use of the gear, and is it ok to put the Aura and the advance both on the 1000W amp. I don't know how much different the two shakers are rated. Thx
I would not put the Auro shakers with the advanced BK4-LFE on the same amp. While it will work, they will give very different effect, and performance could be sluggish. Get 3 more BK4-LFEs and put all 4 on one amp.
Thanks Roman.
While spending $450 on more shakers isn't the answer I really wanted to hear, I appreciate it all the same. :D
1 - 4 of 4 Posts
