1 - 11 of 11 Posts
HTS Moderator , Reviewer
There's no set answer to that I'm afraid, but rarely is anything from the temp folder needed. Even if it is, 99% of that can probably go. Best thing to do is just delete it so the stuff ends up in the Recycle Bin. After a week or two if everything still functions properly you can empty your Recycling. As robbo says, you're bound to have a handful of files that won't delete.
I recommend this forum:
http://qmalwareremoval.freeforums.net/
When you join, you run a couple of scans & post the results in your opening thread. He will get rid of malware that nothing else even sees. And he knows what to delete & not. He will have you download tools, run them. post results, then he will create commands telling the program what to clean. I was referred to him by a Norton administrator when they couldn't fix my problem. He is good. And he is free! Nice to donate though.
Sounds like a good resource to remember.
Is it okay to delete all the stuff in this temp folder? Probably thousands of folders totaling 4.5 gig.
Hello Wayne, I have faced the same problem last month. And this solution has worked for me. Though its a very old post. But shared, If someone gets benefitted from here.
1 - 11 of 11 Posts
