1 - 20 of 29 Posts
Good afternoon everyone. My brother in law and I built my box the other day and it is time to show the progress. The box is currently with my neighbor who owns a custom car shop and is putting a coat of bedliner on it.
I must admit however that I am not too terribly proud of the workmanship but I think it will do for a first attempt. I followed the dimensions provided by Kevin in this http://www.hometheatershack.com/forums/exodus-audio/21979-first-tempest-x2-design-easy-slot-port.html thread. Only a single sheet of 4'X8' MDF was used. My dimensions ended up a little different and yielded 5.7^3 ft and close to 6^ft with 80% polyfill.
We performed this task with the following tools; Skil-saw, jigsaw, hand held beltsander, finishing nail gun. I know most of you use clamps but I was rather impatient and didn't want to wait. Instead, we glued and nailed the pieces together and I predrilled a few holes on each piece and screwed them snug, knowing that any imperfections would be covered by the bedliner coating.
Pics:
Just getting started.
Cutting the hole for the amp.
All pieces cut now ready for assembly.
Partially Assembled
Test fit of the :hsd:
Bracing - does it need more holes???
T-nuts used
Hardware used to fasten the sub.
I will post the final product when I get it back....
Finished but not yet in its final resting place...
Thanks for checking it out...
Brian
I missed the part in the design thread stating the sub works well with the stock HPF. You can get a bit more output at 20 hz if you're willing to modify it.
If that is the BASH amp, it needs to be modified. I think the stock corner frequency is 30Hz. You need to have it set to around 18Hz with a Q = .8 or less.
Kevin Haskins
Exodus Audio
Discussion Starter · #9 · (Edited)
Kevin Haskins
Exodus Audio
Oh man...I thought you were talking about the BASH....you mean I should have purchased the Dayton HPSA500W?
I have read through the BASH tables http://www.parts-express.com/pdf/300-752.pdf and unfortunately I am not sure what resistors to buy/replace...
B
Nice build.
I am looking to build the exact same setup in the coming weeks once I get the funding.
Have you tried it out yet? If so, how do you like the performance?
This will be my first build, fortunately, this design doesn't look to complicated to build and the results should be great!
This exact same design can be done with the port firing to the rear. It is sometimes difficult to finish the inside of the slot port (paint it before you glue it together) and if you prefer not to see the port, it can just fire to the rear over the top of the amp.
Kevin Haskins
Exodus Audio
Discussion Starter · #17 ·
bigdisu1: It hits hard and sounds great but since I have the wrong amp it doesn't go very low...we watched about 10 minutes of Letter of Iwojima and it seemed as though we were onsite. The sub is quite impressive and I look forward to putting the correct amp in when it arrives.
Go for it.
Thanks for the info from both of you.
Another question. What is the best amp to use. Hagarr, I saw you tried the BASH and then you said you were going to try the Dayton HPSA500.
Excuse my ignorance on this part, but in the design notes (http://www.hometheatershack.com/for...9-first-tempest-x2-design-easy-slot-port.html), Kevin suggests the PE 500, but I but I cannot find the PE500 online, I just don't think I know what i am looking for
1 - 20 of 29 Posts
