There's no limit to the shortcuts these installers will take. Remember, they are not paid by the hour, they are paid by the number of installations they do per day - - AND - - they have a minimum quota, which I believe is four.
In our case the Dish (Dish Network) is a pole mount about 60' away from the electrical service entrance. The installer did install a ground block at the coax entry point, but since there was no nearby ground he had to drive his own ground rod..
He pulls out a copper-clad rod from the back of his truck and proceeds to use a hacksaw to cut off a ONE FOOT piece and drives that into the ground at his ground block.
There is no bonding wire to connect "his ground" back to the electrical service ground.
There is no ground on the dish. Okay, it's a pole mount. Is that a ground? Not according to the National Electrical Code.
Another shortcut these clowns are notorious for is failure to install the supporting mast pipe (whether pole mount or otherwise) in a firmly rigid manner that is precisely dead-level plumb. Succinctly stated, it is humanly impossible to achieve accurate and precise alignment of a multi-sat dish unless the mast pipe is absolutely, positively, perfectly plumb. Both Dish Network and DirecTV installers omit this little detail on almost every installation.
You will also find (if you haven't already) that most satellite system installers have extremely little technical knowledge about what they're doing.
