1 - 8 of 8 Posts
after the sweep (or two if I have to load the file in a software stereo) how do I know if this is correct?
in other words, how can I check that the sweep is done right?
thank you.
If you mean how can you check the quality of a measurement, the impulse response usually provides a good indication, when viewed on a dB scale. That makes it fairly straightforward to see the noise level and to check that the impulse response itself looks valid. You can see a couple of examples in the Impulse Responses help.
That dialog is just to set the area displayed on the graph. Have a read through some of the links I posted.
1 - 8 of 8 Posts
