Ten Biggest Audio Lies: Agree or Disagree (If you disagree, you must explain why!) Votes are public!
1 - 20 of 287 Posts
I just cannot resist...
The Ten Biggest Lies in Audio
This is a multiple choice poll, however, if you vote that you agree with all or disagree with all, do not vote on the individual questions or your votes will be deleted.
Do you agree... if not, then why not? (This is not an option... it is a requirement as part of the poll!) If you do not agree, then you must post why you do not agree or your vote will be stripped.
This is a public poll... click any vote to see how members voted.
Play nice ... remember our Forum Rules and Zero Tolerance!
Congratulations... you have found the missing link!
What did I win?? :jiggy:
Looks like there might be a permission or missing document problem.
It made me laugh to read them all as I totally agree with all of it. I know someone on here is going to pipe in say that they could prove that they are wrong but I always say if your ears cant hear or see a difference who cares what the scopes and other electronic testing equipment says.
Nice. I am glad to hear that I am not alone thinking that there is a lot of mumbo-jumbo in the audio world. I must admit that several years ago I fell victim to the cable/interconnect lie. I spent about $40 (at the time that was a lot of money for me) on a pair of stereo RCA-RCA cables that looked a lot cooler than the patch cords that came with the CD player, when the salesman promised that they would improve the sound. I proceeded to hook them up and hide them behind my equipment, resulting in no difference in sound quality what-so-ever. Still have those cables, still use them, still think they look cool when I rewire something, and still think I got ripped off!!!
Super Moderator
Here’s my favorite quote from the article:
If you can afford a fancy power conditioner you can also afford a well-designed amplifier, in which case you don’t need the fancy power conditioner.
I pretty much agree with all of it, except for the cables. I generally not a believer in that stuff, but I have seen two instances where I could hear a difference. Which was surprising, because I wasn’t expecting anything at all. So I’m hesitant to denounce the idea outright.
Just go into it with clear eyes and know that you're just spending the extra money for aesthetics.
Aesthetics that no one will ever see... Now that I don’t get. :huh:
I never could figure out the ABX foes, with their complaints about additional switches, etc. How many switches and relays does the signal go through as it is? Let’s see, the pre-amp source selector, the amplifier relays (that many have), the amp’s speaker selector switch, etc. Silly, just silly. :dizzy:
There are certain situations in which different cables will be audible, but this is only if the cable is either not designed properly or is not being used properly such as if the cable is not of sufficient gauge for run length in relation to resistance.
Super Moderator
But would you expect to hear a difference on lower-end PA speakers??? Needless to say, it was shocking...
That is pretty surprising. What kind of cables were they? It sounds like they were designed like complete and utter poo and that is just plain hard to do maybe there was a goal with those cables? I have encountered a pair of cables that were designed specifically to EQ the high end for a gradual roll off.
Yes. The cables act in concert with the speakers and the amp as an RLC system and the author mentions this in the article. If there's something funky on one side of the cable, or if there's something funky with the cable then it's possible that it could make a difference. The catch is that there's no guarantee or 'spec' you can look for. It's possible that in one of these senarios the cheaper wire may sound better!
article said:
The truth is that biamping makes
sense in certain cases, even with a passive
crossover, but biwiring is pure voodoo.
my amplifiers manual said:
If only one speaker is to be used, connect it to the SYSTEM (A) terminals.
I do this. I use my receivers amplifiers also. I plan not to later on when/if I have more sensitive speakers. :surrender:
Super Moderator
That is pretty surprising. What kind of cables were they? It sounds like they were designed like complete and utter poo and that is just plain hard to do maybe there was a goal with those cables?.
Well, you probably won’t believe this – I still can’t believe it.
Everything was set up in our warehouse-cum-showroom, and we were using an old Technics CD player with both RCA and balanced XLR outputs for demo purposes – or in our case, just to have some music to work to! Typically we were using the RCA jacks, but for some reason one day I used the balanced – maybe the RCA cables were missing, I don’t remember. Just used some cheap mic cables we had laying around (which is what we mostly sold). Well, I was amazed at the improvement in SQ, just by using the XLR connections over the RCAs. Sure wasn’t expecting anything. You can bet I was using the XLRs exclusively after that!
Here’s the kicker: Sometime later I popped the cover on that Technics CD player and almost had a heart attack at what I saw. It really didn’t have balanced outputs at all. Someone had retro-installed some chassis-mount XLRs and wired them directly to the RCAs!!!!!
‘Course, now that I think about it, it’s possible the difference could have come from using the mixer’s balanced inputs instead of unbalanced. There will be some extra circuitry involved at the console, even if the source isn’t balanced.
Plain ole user
Most of the "lies" I generally agree with, but nearly all of them has some caveat that needs to be considered or some degree of truth to it. The problem is that rather than getting to the bottom of why people experience what they feel they do, one side wants to promote the idea as the be-all and end-all and the other side is bent on proving them wrong.
Science that starts with the goal of disproving lies is as wrong as the lies themselves. It may seem to justify self-righteousness, but it simply polarizes. In most of the debates and arguments about these issues that I have experienced, there is more interest in proving one's point than interest in learning, discovery, and the search. This is unfortunate, because we have so many great tools that could be applied to both the hardware and the perceptual parts of the experience. Home Theater Shack at least has some open minded people who are willing to discuss hese matters in a civil discourse without the vitriole.
Like my sig on AVS reads...the correct answer is, "it depends."
I can agree with all except the power conditioner. The difference I found was on the video side, however. I could never tell a difference with audio, but I noticed less "ziggy's" on test patterns with my PJ.
Sonnie . Isn't it good to expose all the lies to all the members . At Last . If there is a member who has been hypnotized by a unscrupulous salesmen may he awaken to the lies . Alan .
I thought I would end up disagreeing with several points, but he always qualified his statements right at the end:
-Speakers and headphone potentially benefiting from break-in
-LP superior to CD because of mastering differences
-Bi-wiring is not bi-amping
It is interesting to see the people who do disagree though.
Discussion Starter · #20 ·
Those who disagree should state why they disagree... just as James did about the power conditioner. Obviously it made a difference and it would be nice to know why it did if anyone would have an idea. I meant to make it a public poll, but I guess I forgot to check the button.
1 - 20 of 287 Posts
