Hi everyone!
i'am new here at the forum so just wanted to show my special theater room!
Info aboute the theater system:
The system is placed in a old shelter-room in the basement and it's a 7.2½ system with totalt of 22 speakers, 8 of those are right behind the sofa , 2 st dipol speakers 1.3 meters above the sofa to spread sound up&down and 4 side surround speakers and 4 sub/mid woofers and 2 front speakers and 2 center speakers.
The 2 massive T-line steel/metall pipe is dubble "folded" so that the port is round the sub total leght is around 3.1 meters(like 10 feet or so), i use 2 15" kicker CVR 500w woofers and they are used as infra-subwoofers(18-40hz) so the tunning frekvenzy is 28 hz and goes down to 20 hz even without losing any presure, at 14 hz the dead end is reached. for midwoofer i use 2 Zomax/JBL 2226 15" to play the bass over 40hz to 80hz. one bass shaker tuned to 14-19 hz to get the lowest bass!
The total RMS output from the amplifiers is around 2300 watt(8 ohm) at this moment. gives 134.3 [email protected] hz
The picture is Panasonic PT-AE900E giving with a HTPC and sends out those BluRay/dvd i plays, the system goes with 720P and that gives a good quality picture.
The theater in the shelter room is built from scratch, Floors, painting sound damping was made to make it a nice theater. The 30-45cm (12-15inch) thick walls is not ideal for good akustics but with loots of damping in both sub frekvenzys and higher frekvenzys it turened our realy good. An extra power cable is going in the room to feed the subwoofer amps, the fuse is set to 16 Ampere, only t.amp can draw 15 Ampere at full power.
And i have no neigbours to disturb here so thats good!
The carpet flyes away!
dB mesurement!
edit: added some new pics!
dB mesurement!
